cschmid
 - Northern cold country
why was it good enough in the past and now it is not? some sort of incident I have not heard of..
			How about NM being exposed to dampness?
In the current issue of Electrical Contractor there is a question about romex in exterior receptacle and light boxes. They say it is not allowed.
That is a good point. If there is nothing to inspect he must not be ready for a rough-in. As pointed out earlier on a rough-in all that will be covered up must be visible and ready for inspection. I have no intention of removing devices on a final inspection unless I am suspicious of non-compliance. If I see insulation debris from a fixture on the floor,which I have on occasion I will take a fixture down. Guess what I find!!!! Don't make me take it apart on a final. Make it easy on yourself and have it ready for a rough-in. It is a lot easier to clean up on rough than on trim out. GC or owner is not so picky about a piece left here and there on an unfinished floor.OK for the sake of argument what is the inspector even looking for at this box?
IMO without the grounds made up there is nothing to inspect.![]()
I noticed that too and sent Mr. Trout an e-mail asking for clarification, he replied that the box recessed in the wall was not what he was talking about, only exterior wiring (I assume to include surface mounted bell boxes?)In the current issue of Electrical Contractor there is a question about romex in exterior receptacle and light boxes. They say it is not allowed.
If the box is sideways. is it ground to the right or to the left?![]()
See Dry Locations, Article 100
What does the location have to do with the wire?
You asked about the wire getting damp in reply to violations, correct ? As I'm sure you
know, a location classified as dry maybe temporarily subject to 'dampness' or 'wetness'; as
in the case of a building under construction.
The building in George's picture is under construction.
So are we now going to say the inside of a 3r panel is WET ? I hope not or i wasted my money
Under construction does not give us permission to expose NM to 'water'.
Here in Ohio if you run NM in a home and it gets wet the inspector will make you remove it.
