LarryFine
- Henrico County, VA
- Electrical Contractor
I'm so confused. What's "the" conclusion? Intermediate securing needed or not?Give it up, it's done. :grin:
Don cleared that up entirely, he provided the names for the parts that make up the truss and showed that the http://www.icc-es.org/ considers a truss a framing member and that should be a rock solid source of that type of info.
Is the majority correct because they're the majority, or are they the majority because they're correct?See the poll
We need Electripedia.Listen. I can provide documented proof that I am right about this. Just give me 10 minutes, then go check Wikipedia!![]()
Are you serious or kidding?:-?
It does NOT take that much more time or effort to secure the blasted conduit at the proper intervals. Sheesh.:roll:
Doesn't matter, it's not required.
Roger
So you would compromise the quality of your work simply because it's not required? :-? This is something that does not substantially increase the cost in material or labor to ensure a SAFE, SECURE and professional looking installation.
I don't know about the rest of you, but I take pride in my work and I frequently go above Code minimums to make sure that what I install not only is durable but looks better than the other guys' so I'm the one who gets the callbacks to do more work. :grin:
I'm serious
as I have seen EMT in installations that looked like snakes and had separated couplings because it was not SECURED
at the required intervals.
The EC's I have worked for would never even allow an installation that wasn't secured properly.
Like Jim said, common sense has to take hold here and if the CMP is too darn blind or stupid to see the issue, then it's time the CMP had some new members put in place.
Joseph Dabe, City of St. Paul, MN [L]
Rep. International Brotherhood of Electrical Workers
George R. Dauberger, Thomas & Betts Corporation, TN [M]
Rep. National Electrical Manufacturers Association
James C. Dollins, Tyco/AFC Cable Systems, MA [M]
Rep. The Aluminum Association
James T. Dwight, Sasol North America, Inc., LA
Rep. American Chemistry Council
M. Shan Griffith, Kellogg, Brown & Root, Inc., TX
Rep. Institute of Electrical & Electronics Engineers, Inc.
David G. Humphrey, County of Henrico, Virginia, VA [E]
Rep. International Association of Electrical Inspectors
David H. Kendall, Carlon, Lamson & Sessions, OH [M]
Rep. Society of the Plastics Industry, Inc.
Richard E. Loyd, R & N Associates, AZ [M]
Rep. American Iron and Steel Institute
Stephen P. Poholski, Newkirk Electric Associates, Inc., MI
[IM]Rep. National Electrical Contractors Association
George F. Walbrecht, Underwriters Laboratories Inc., IL [RT]
Leslie R. Zielke, South Carolina Electric & Gas Company,
SC [UT]
Rep. Electric Light & Power Group/EEI
Alternates
Richard J. Berman, Underwriters Laboratories Inc., IL [RT]
(Alt. to G. F. Walbrecht)
Joyce Evans Blom, The Dow Chemical Company, CA
(Alt. to J. T. Dwight)
Duane A. Carlson, PRS Consulting Engineers, WA
(Alt. to M. S. Griffith)
Charles W. Forsberg, Shaker Heights, OH [M]
(Alt. to D. H. Kendall)
James M. Imlah, City of Hillsboro, OR [E]
(Alt. to D. G. Humphrey)
Kevin J. Lippert, Eaton Corporation, PA [M]
(Alt. to G. R. Dauberger)
Gregory L. Maurer, Wheatland Tube Company, AR [M]
(Alt. to R. E. Loyd)
Gary W. Pemble, Montana Electrical JATC, MT [L]
(Alt. to J. Dabe)
C. Ernest Reynolds, Hatfield-Reynolds Electric Company,
AZ [IM]
(Alt. to J. R. Burns)
Richard Temblador, Southwire Company, GA [M]
(Alt. to J. C. Dollins)
MX, I don't think he's debating the way he would do it, but rather how the code is written. You should know that
The Code isn't ALWAYS right or safe and this situation is a prime example of how wrong the Code is.
Yes, I would have my people put a piece of tie wire around it at intervalls but I wouldn't be to concerned about the spacing nor would I make a special trip back to a job site if it were not done.
I was not asking if you would secure it, I was asking if you seriously still believed the NEC requires it to be secured?
Anything can happen and often does.
That has been the question all along, what is required, not what is better.
Again what is 'properly' if the it is installed per the NEC IMO it is done properly even though it could be done better.
Perfect, again the tradesman that is sure they know so much more than 100 years of code making.:roll:![]()
The code is written by us, submit a proposal with more substantiation then a personal opinion and it may get accepted.
Here are the folks you feel you know better than
That was never the subject of the threads was it?![]()
Because you have deemed it so.
You don't find that the least bit egotistical?
I mean hell, I have an ego as large as Antarctica :grin: but I still cannot convince myself I know more than 100 plus years of code making overlooked by 1000s of educated people.![]()
McClarry is right, the conversation is about code so you can get down out of your high horse saddle now.
Roger
Yes it is
Roger
I ran a crew doing a fire alarm system for a new Lowes, I had the guys use tie wraps to secure the 3/4" EMTs to the trusses.
The proposals posted so far seemed pretty solid to me though.
