 - Illinois
 - retired electrician
Yes that is the question, and you said under the outer covering of the building is not inside. If that is the case than it should be clear that under the building is also not inside the building, but we needed a specific code rule to tell us that under the building is not inside the building.That said, I don't see the reason for you bringing up 230.6...
...the question here is what criteria determines the inside-outside boundary.
