resistance
- WA
Must be a big box store.I wont say name of supplier but it is over with the decorative accent recessed lights where they also have the tiny ones .120 v
GESH....why did I not think of that and making easy money versus writing books and conducting seminars.......![]()
Don't you hate it when the drywaller cuts his hole 3/4" off and corrects it by hammering the recessed can over to match his hole?All that time getting the line perfectly straight for nothing!
I don't know what all the fuss is about. :-? I do what the op wants all the time. I just finished roughing a kitchen. I left my wiring in place where 8 cans are to go and marked the locations on a plan. I will cut the lights in after the ceiling is up. I need to be closer to ceiling joists and I will have a better shot at lining up the cans on cabinets after the cabinets are in place.
I have installed thousands of remodel cans. I have never seen drywall sag and if the can is coming out of the ceiling after install you are not installing them correctly. Also if you can't cut the hole correctly then you might consider finding another line of work.
To the op, don't let these guys deter you. You had a good idea that is perfectly legal and will result in making things easier for yourself.
I like that accessory; it's great for speaker holes, too.I have the circle cutter for my Roto zip which works great for old work cans.
1000%? Were you on the Maury show?... after many of the contractors started back charging they improved 1,000%
IC cans can be in contact with combustible materials. With the mounting bars and can frame it is often impossible to get tight to a joist with a new work can. Using remodel cans can make a 1-2 inch difference which in a kitchen application is a big deal.
Will you get flagged on new work for leaving the wires in place to install remodeling type can lights instead of mounting the new work can lights.
I would think that most of the contractors here have successfully used remodel style cans, including myself. And when I had to do what the OP is suggesting (installing remodel cans after the fact), I've never failed an inspection.
That being said, my experience has been that, at times, homeowners will end up pulling remodel cans out of the ceiling when they're trying to change lamps. Even though it's not my fault, who looks bad?
So my preference is to use new construction cans, or barring that, to get a screw or two through the remodeler can into wood to help support it. At times, when the roof is shallow, you can even get a short screw through the top of the can into the roof sheeting.
Thats why I am tempted to use the remodel cans but no one seems to agree.
BS...1 inch is the most you can get closer and I can get within 1/2" with the bracket of an H7ICT- so 1/2" is the difference. I misspoke on the ICT - I thought they had to be 1/2" from wood-- I think they used to anyway.
Retro cans cost me upward of $16.00 while a H7ICT is $6.95. If you think that is worth a 1/2" then by all means but it is a rare situation where it is that important.
You should shop around for a new remodel can.
5" Elite IC new work $7.67
5" Elite IC Remodel $7.66
Tghe remodel is cheaper.
Pennies from heaven suckers!![]()
