Romex switch legs
when i do a rough and they want a ceiling box for future light i install a fan box alllways and run a 3 wire from the switch.in case they wan a thchange to a fan in the future:grin:
There are those that will blast you for typo's on here , believe me I know. I have never had the pleasure to find a ceiling box wired that way when going back to install a fan , but that is great for the next guy when you do that. :grin:
If you think NM is a raceway, try pulling a red 14 into a 14/2 from the ceiling fan to the switch.;)
If you can do that, and not exceed the 'jacket fill', I'll start calling NM a raceway.
Believe it or not I saw a guy that was going to have to make a 35 mile trip back the next day because he didnt have a 2 ft longer piece of 14/3 , he set a j box in attic and took a 2 ft piece of 12/2 and soldered a #14 insulated and a #14 bare ground to the #12 bare ground and by pulling out the #12 bare ground he managed to get the 2 # 14 's in , #14, #12 and #10 nm were all colored white in those days. I asked why he didnt just run 2 pieces of #14-2 nm and he said an inspector wont notice it this way but will notice conductors not in the same cable or raceway . :roll: :confused: :)
I am a Master Electrician in six states not a journalist for the new york times:grin:
I'll be the first to tell you that i could not spell my way out of a paper bag.
We are all here to learn about how to get around the code book faster and better so if i spell somthing rong by all meens make sport of me i will be laughing too!:grin::grin::grin:
Well I don't think EMT has a busbar either. :grin:
Grab a stick of EMT with one hand, hammer with the other, smash liberally -- instant busbar.
When I was still doing volunteer electrical work for Habitat for Humanity, we were installing a heat / vent / fan fixture in the bathrooms. The guy who led the crew managed to find 14/4 -- black, red, blue, white and bare copper.
Instead of running 3-wire, you have a choice -- you could run 4-wire instead ;)
Thats a good one, back in my day men did not take typing in school, we had a name for the ones that did ;) . we also didnt care much for spelling and english. My subjects were physics. calculus, and chemistry. Little did I know I would one day be faced with a computer keyboard. Now I pay the price :D
Taking power to the light, then running 3-wire cable to the switch, would still be perfectly legal.
I am trying to find a way to keep from wasting a lot of wire with the 2011 code. Running the power to all the switches boxes first then a 14/2 or 14/3 (for ceiling fan) adds up to a lot more cable than the old way of hitting all the ceiling boxes with power and using the switch legs. The problem is for a ceiling fan with light you would need 14/ 4 to run to the switch, neutral, hot traveler to switch , hot back to light, hot back to fan. My question is 14/4 is not available around here in nm . would it be against the code to run 2 14/2 from ceiling to switch , one for neutral and hot , the other 14/2 from switch for the light and fan . Can the white be used this way if marked? It is not the same as a traveler down this way .?
Jetlag, it's time to change your evil ways , baby. You can run 2 sets of 14/2 as long as it is nm cable but they need to be run together to minimize the emf's that are produced if separated. Not a good way to do it.
I haven't seen anyone run the power to the lights in over 30 years around here. All power is in the switch boxes-- easier to make joints etc.
14/3 is available everywhere. Run power to the switch first, then 14/3 to the fan/light. Why bother taking power to the ceiling, then trying to either find 14/4 or cobble something up with 2 runs of 14-2?
Either that, or run power to the ceiling & leave it there, and install an RF-controlled fan/light. NOW look at how much NM you've saved! :D
I have no doubt that more & more supply houses will start to stock 14-4 very soon.
14/3 is available everywhere. Run power to the switch first, then 14/3 to the fan/light. Why bother taking power to the ceiling...
To save wire, if your light is close to your panel, then run 14/2 there and 14/3 to the switch. If you're wiring a fan/light, then it makes sense to hit up the switch box first.
If you used the 14/2 as two seperate switch legs, could this be considered parallel conductors?
Draw out a simple plan and you will see the amount of wasted cable when running the power to the switches first , the 14/4 should not be much more expensive that 14/3 unless they want to burn you for a rare item . For lights without a fan the 14/3 can be used , Im only looking at 4 or 5 pieces of 14/4 in most houses. But my question was can a 14/2 be used with both conductors as a return from the switchs with the traveler to switch in another cable ?
You must do some very weird wiring.
You need cable between the switch and ceiling, no matter what.
Why not use 14/3 instead of 14/4?
As for cost, look at the price difference between 14/2 and 14/3, then extrapolate to 14/4. 14/3 is not just 33% more than 14/2 simply because it has 33% more conductors. It's more like 50% more. So if 14/4 is 50% more than 14/3............ Well, you do the math.
If you want to cobble together two 14/2 between the ceiling & switch, start looking at your labor units.
I think the idea behind this is not to have two white wires coming in to a light fixture
IMO, the red or black 'hot' is the only thing that should be feeding a load.
IMO, the white has to be marked so that
it fits into the scheme of only colored wires being used to feed a load.
I think we should be emphasizing that only colored wires are feeders.
Thus, when the white is marked,
it then becomes like the colored feeders.
Draw out a simple plan and you will see the amount of wasted cable when running the power to the switches first ,.......
Wow. You're right! I'm saving a TON of wire! :D
Its not "weird" to hit a ceiling box first when power is near by, and when it is not far to ceiling box in the next room. Where did I say no cable was needed between the switch and ceiling ?? I did do the math but you must not have tried a simple lay out . Now matter what hitting the ceiling box first uses less wire and the labour is the same
