And many will not.
Here in MA you can work on your own place.
Yes a homeowner can do his own Electrical work in the home he lives in , but still must pull a permit and have the work inspected by the Electrical inspector
And many will not.
Dr. Handyman
It's like a toupee. You only see the bad ones.
Yes a homeowner can do his own Electrical work in the home he lives in , but still must pull a permit and have the work inspected by the Electrical inspector![]()
No that is false, some towns say that but it is not backed up by any MA regulation.
Same thing goes the other way too, having an electrical license and owning an IR camera does not make you a thermagrapher, or downloading some software does not mean you should be doing arc flash or coordination studies. EE's have to deal with the same "DIY" type competetion from under qualified people.
I know you guys hate to hear this but the work we do in most homes is not rocket science. :grin:
If questioned all he needs to say is he is doing the job for free. No paper trail = no taxes
How about not for hire (no payment), but in exchange for good and/or services. Legal?
'Install that thar plug fer ya'll in 'stange for some home cookin' dinner!'
Methinks the IRS would consider such a trade as income. You received something of value in exchange for the services rendered.
Bob
It is in the massachusetts building code CMR 780 51.00.
http://www.mass.gov/Eeops/docs/dps/BuildingCode7th/780051.pdf
Section 5110.1 of the 7th Edition of the Massachusetts State Building Code
If you read here:
http://www.malegislature.gov/Laws/GeneralLaws/PartI/TitleXX/Chapter143/Section3l ("Regulations relative to electrical wiring and fixtures; notice of electrical installation")
"No person shall install for hire any electrical wiring or fixtures subject to this section without first or within five days after commencing the work giving notice to the inspector of wires appointed pursuant to the provisions of section thirty-two of chapter one hundred and sixty-six. Said notice shall be given by mailing or delivering a permit application form prepared by the board, to said inspector."
Sounds to me like if "not for hire", no requirement for a "permit application". But then again, I'm not a lawer...
CHAPTER 141 Section 1A. No person, firm or corporation shall enter into, engage in, or work at the business or occupation of installing wires, conduits, apparatus, devices, fixtures, or other appliances for carrying or using electricity for light, heat, power, fire warning or security system purposes, unless such person, firm or corporation shall be licensed by the state examiners of electricians in accordance with this chapter and, with respect to security systems, unless such person, firm or corporation shall also be licensed by the commissioner of public safety in accordance with the provisions of sections fifty-seven to sixty-one, inclusive, of chapter one hundred and forty-seven.
This chapter shall not apply to: a person not engaged in the business described in this section who employs or contracts for the services of a person, firm or corporation engaged in such business; or to an apprentice employed by a person, firm or corporation licensed in accordance with this chapter; or to an agent, employee or assistant of a person, firm or corporation licensed in accordance with this chapter who does not engage in or perform the actual work described in this section.
As far as I can find, it says nothing about electrical permits - just says "obtaining the required building permit and all other required permits". If you read here:
the words "For hire" aplies to "US"licensed Electricians, not handyman or homeowners.
5101.5 Specialized Codes. In accordance with
M.G.L. c. 143, ? 96, specialized codes, rules or
regulations pertaining to building construction,
reconstruction, alteration, repair or demolition, and
inspection promulgated by, and under the authority
of the various boards which have been authorized by
the general court shall be incorporated into
780 CMR 51.00 through 99.00. Areas regulated by
the specialized codes shall require that all such work
performed is designed, installed and inspected in
accordance with the specialized codes. For
governing regulations addressing the approval,
design, installation and maintenance of
fossil-fuel-burning appliances, refer to the
Massachusetts Fuel Gas and Plumbing Codes (248
CMR) for gas and the Massachusetts Fire
Prevention Regulations State Fire Code (527 CMR)
for oil. Applicable specialized codes, rules or
regulations relating to building systems include, but
are not limited to, those identified in 780 CMR
5101.5.1 through 5101.5.7 and those listed in
780 CMR 100.
5101.5.1 Electrical. Massachusetts State
Electrical Code (527 CMR 12.00
