jwelectric
 - North Carolina
Mobile VS Manufactured.
In 550.2 it said that they are basically the same. Unless otherwise indicated.
550.32 is one of those examples.
I have no problem with 550.33(B).
Manufactured Home. A structure, transportable in one or more sections, that, in the traveling mode, is 2.4 m (8 body-ft) or more in width or 12.2 m (40 body-ft) or more in length, or, when erected on site, is 29.7 m2 (320 ft2) or more and that is built on a permanent chassis and designed to be used as a dwelling, with or without a permanent foundation, when connected therein. The term manufactured home includes any structure that meets all the provisions of this paragraph except the size requirements and with respect to which the manufacturer voluntarily files a certification required by the regulatory agency, and except that such term does not include any self-propelled recreational vehicle. Calculations used to determine the number of square meters (square feet) in a structure are based on the structure's exterior dimensions, measured at the largest horizontal projections when erected on site. These dimensions include all expandable rooms, cabinets, and other projections containing interior space but do not include bay windows.
For the purpose of this Code and unless otherwise indicated, the term mobile home includes manufactured homes.
FPN No. 1: See the applicable building code for definition of the term permanent foundation.
FPN No. 2: See Part 3280, Manufactured Home Construction and Safety Standards, of the Federal Department of Housing and Urban Development, for additional information on the definition.
Mobile Home. A factory-assembled structure or structures transportable in one or more sections that are built on a permanent chassis and designed to be used as a dwelling without a permanent foundation where connected to the required utilities and that include the plumbing, heating, air-conditioning, and electrical systems contained therein.
Where are you getting the requirement that these two are separated in some way? Look at the underlined section of the definition of Manufactured Home and it is clear that HUD can label a single wide as a manufactured home.
