 - Bremerton, Washington
 - Master Electrician
Bridgeport has a new "mighty ground" fitting, the MCC-050 and 075 that is similar in function to the Kenny Clamp.
http://www.bptfittings.com/images/whatsnew/Grounding Products Flyer.pdf
I have used and like the Kenny Clamp. Its a brass compression fitting designed to clamp the GEC where it enters a panel to comply with section 250.64(E)
While not all forum members will agree that such a solution is required, either product is a better way to run a GEC than thru a romex clamp.
And its nice to see mfgs developing products, perhaps now we will see some field installations of these.
