Jim W in Tampa
- Tampa Florida
I haven't dealt directly with the inspector, but a friend of mine that is an electrician and also works at Lowes has. He should know about the DW mfg. allowing the cord connection. He was getting a rough inspection and the inspector asked him about the DW receptacle and he quoted him the code ref. to the cord connection. The inspector's reply was "not in my town do you use a cord connector for a DW. I want it hard wired." End of story.
Lets start by putting that inspector in his place. It is not his town, it simply is the town he works for and perhaps some pressure can change that.
As far as direct wire yes it is one of the ways allowed by nec. It will need breaker lock or a switch but i see no reason to add cost of switch unless you can't locate a breaker lock.
You need check to see what ammendments your town has in writing. They over ride nec
