Because the page actually has many more flanged devices on it, I only posted the inlet.Why does it say "Inlets and Receptacles"?
Roger
I am not ready to offer an opinion, because I am not sure I understand the concept. Tell me if I have this right:
1. You permanently mount a standard (single or duplex) receptacle outlet high on the wall, at the location of the TV mounting chassis.
2. At the more usual receptacle height, and directly below item #1, you permanently mount a ?thingy that looks like a receptacle, but has male connections visible sticking out from the wall.?
3. Within the wall, you use an allowable wiring method to permanently connect items 1 and 2.
4. You now use something that resembles a conventional extension cord, plugging the male end into a standard receptacle outlet, and plugging the female end into item #2.
5. What this gains for you is the ability to have a new receptacle for the TV, without using an allowable wiring method within the walls to permanently connect the new receptacle as an extension of the circuit serving the existing one.
If that is how this system works, then how does it get past the second sentence of 406.6(B)? By my reading of the article 100 definition of ?receptacle,? that definition does cover ?Item 2? above.
Agreed- my dishwasher and garbage grinder both cord have cords on them and have not been unplugged since they were installed more than ten years ago, like fourteen. When do they become permanent?It's no more permanent than every other cord we leave plugged in 24/7/365. I have cords that have not been unplugged since we moved here over 10 years ago. Are they permanent? What if I plug in something attached to the wall?
Still agree, however, I wish my TV was part of the permanent wiring system. It would cut down on my wife rearranging the furniture!!...to me is is no different then a TV being plugged in and saying the TV is part of the fixed wiring system. It is not part of the system in my eyes.
I don't think this would be code compliant but wouldn't it make sense for the manufacturer to go to the NFPA for an opinion?
Chicken! :grin:
Not in my opinion. I equate it to leaving Christmas lights on the gutters year round. Neither constitutes an electrical installation. The thing that is an electrical installation is the thing that brings power to the utilization devices.Is it a violation when the two boxes, devices, and NM is installed in the walls with no power applied?
In my opinion, yes. I have already cited the relevant article: the second sentence of 406.6(B). I have not yet seen a convincing argument that (1) The ?inlet? does not meet the definition of a ?receptacle,? and (2) The female end of the power cord does not meet the definition of an ?attachment plug.?Is it a violation to use an inlet to feed in wall wiring?
Not in my opinion. I equate it to leaving Christmas lights on the gutters year round. Neither constitutes an electrical installation. The thing that is an electrical installation is the thing that brings power to the utilization devices. In my opinion, yes. I have already cited the relevant article: the second sentence of 406.6(B). I have not yet seen a convincing argument that (1) The ?inlet? does not meet the definition of a ?receptacle,? and (2) The female end of the power cord does not meet the definition of an ?attachment plug.?
I will say this about the strength of my reasoning: If the state of Washington, or any other AHJ, were looking for an NEC article that they could cite as the basis for forbidding the use of this equipment, I believe they would win any court case if they were to use 406.6(B) as their basis.
Attachment Plug (Plug Cap) (Plug). A device that, by insertion in a receptacle, establishes a connection between the conductors of the attached flexible cord and the conductors connected permanently to the receptacle.
... I have not yet seen a convincing argument that (1) The “inlet” does not meet the definition of a “receptacle,” and (2) The female end of the power cord does not meet the definition of an “attachment plug.”....
Good point.Okay, considering your argument of 406.6(B) where could this inlet device "Attachement Plug" be used?
Gender indicated; works for me!Attachment Plug ? A male contact device for the temporary connection of a flexible cord or cable to a receptacle, cord connector, or other female outlet device.Male Inlet (Equipment Inlet, Motor Attachment Plug) ? A male contact device to be mounted on utilization equipment to provide a detachable electrical connection to an appliance coupler or cord connector.
Thank you, Justin.The OUTLET and INLET are not listed from PowerBridge as separate components but as a KIT. They have specific labeling and instructions to the listed use as an IN WALL ELECTRCIAL APPLIANCE. Appliances are allowable to be energized by cord-sets.
I can. So far, I have only installed mine, not the packaged kit, and I will continue to do so.So the question I have is:
Who can install this product?
OK. When the 2014 NEC comes out with an equivalent revision to its article 100, I will withdraw my use of 406.6(B) as objection to this device. As I said earlier, I don't see a safety issue here. All I see is a set of words that, at the moment, tend not to allow the use of this equipment.How about the definitions in the UL white book for ATTACHMENT PLUGS (AXGV)?
In my State, even low voltage installers and low voltage contractors are licensed.Who can install this product?
Nowhere, I suppose. Or perhaps I don't quite understand the nature of an inlet device. I haven't been looking closely at the discussion and the equipment cut sheets for things other than the original topic of this thread. Does the NEC address an "inlet device" anywhere?Okay, considering your argument of 406.6(B) where could this inlet device "Attachement Plug" be used?
That said, there is a third category of installers that you didn't include in your post. The Do-It-Yourselfer, who is the owner / occupant of a detached single family dwelling, is entitled, in many jurisdictions, to pull their own electrical permit and do their own electrical installs.
Stick around. This thread is still rolling, in my opinion, and more information will develop, I suspect.
There are 34 instances of "inlet" in the NEC + Handbook commentary.Does the NEC address an "inlet device" anywhere?
2008 NEC
Article 626 Electrified Truck Parking Spaces
626.2 Definitions.
Cord Connector. A device that, by inserting it into a truck flanged surface inlet, establishes an electrical connection to the truck for the purpose of providing power for the on-board electric loads and may provide a means for information exchange. This device is part of the truck coupler.
So If the "reverse receptacle" were not recessed, you would not see a code violation?The ?reverse receptacle? has its blades recessed deeper into the wall space than the front surface of the receptacle. When you bring the female end of the cord close to the blades, the front face of the cord cap has to cross beyond the front face of the receptacle, before the two components come into actual contact. At the moment the border is crossed, the cord cap has been ?inserted in? the receptacle. So I say again that the definition of ?attachment plug? encompasses the female end of the cord.
