Conduit on outside of building
Alwayslearningelec
NJ
Estimator
Just curious. If there were several conduits running along the outside of a existing building vertical about 8 stories what would be the best method for gainging access to do this work? Scaffolding only? Thanks.
don_resqcapt19
Illinois
retired electrician
There are plenty of bucket trucks and boom lifits with 120'+ sticks. If the conduit is running vertically make sure you look at 300.19
infinity
New Jersey
Journeyman Electrician
All scaffolds over 40' in NYC require design by an architect or engineer and all workers working on a scaffold above 40' are required to be licensed. Keep that in mind if you're looking to work on an 8 story scaffold.
tkb
MA
Don't forget about conductor support. 300.19
Use a bosun's chair from the roof.
Alwayslearningelec
NJ
Estimator
Thanks. I actually heard someone talking about it and I was curious.
Alwayslearningelec
NJ
Estimator
I think you are in over your head again.
Nah my good ole pal..just curious about this. I am not working or estimating this in anyway.
Yes I have heard conduits called sticks...when just referring to the conduit without couplings etc. And yes I believe a bolsuns chair is more commonly used in a shaft...am I wrong. You have a wonderful day.....rather night.:grin:
John120/240
Olathe, Kansas
Correct you are, a bousuns chair could be used in a shaft. The refrence to "stick"
was made concerning a boom lift. Think of mulitple sections of steel tube that
slide inside each other. There would be a basket attached to the end of the stick.
You can check a manfacturer's web site, such as 'JLG" and others.
Alwayslearningelec
NJ
Estimator
Ty very much.
renosteinke
NE Arkansas
May I ask a silly question?
How do they wash the windows?
A building that size almost certainly already has provisions for mobile scaffolding. Maybe you can work off that.
