Conduit on outside of building
Alwayslearningelec
NJ
Estimator
Just curious. If there were several conduits running along the outside of a existing building vertical about 8 stories what would be the best method for gainging access to do this work? Scaffolding only? Thanks.
There are plenty of bucket trucks and boom lifits with 120'+ sticks. If the conduit is running vertically make sure you look at 300.19
All scaffolds over 40' in NYC require design by an architect or engineer and all workers working on a scaffold above 40' are required to be licensed. Keep that in mind if you're looking to work on an 8 story scaffold.
Don't forget about conductor support. 300.19
Use a bosun's chair from the roof.
Thanks. I actually heard someone talking about it and I was curious.
I think you are in over your head again.
Nah my good ole pal..just curious about this. I am not working or estimating this in anyway.
Yes I have heard conduits called sticks...when just referring to the conduit without couplings etc. And yes I believe a bolsuns chair is more commonly used in a shaft...am I wrong. You have a wonderful day.....rather night.:grin:
Correct you are, a bousuns chair could be used in a shaft. The refrence to "stick"
was made concerning a boom lift. Think of mulitple sections of steel tube that
slide inside each other. There would be a basket attached to the end of the stick.
You can check a manfacturer's web site, such as 'JLG" and others.
Ty very much.
May I ask a silly question?
How do they wash the windows?
A building that size almost certainly already has provisions for mobile scaffolding. Maybe you can work off that.
