Rick Christopherson
People, yes. Linemen, no. :lol:You would not have spent days on this thread if you did not care what people think of your beliefs.
Do you think asking it 12 or 13 times will make it any less of a stupid question? It is no different than your rectifier circuit. One SCR is operating on the positive half-cycle and the other is operating on the negative half-cycle. It is not magic and has nothing to do with a phase shift. Each diode or each SCR is forward/reversed biased every half-cycle. The half-cycles are 180? apart, so of course you have to fire the SCR's at 180?. You would have to do the same thing if they were connected to a single-winding too. Either you are being deliberately deceptive or incredibly...... :dunce:Then how about you give your expert opinion on exactly why the two pulses in the SCR circuit I posted have to be 180 deg apart?
Because you labeled your nodes 120V, 0V, 120V. I've said this several times, but you didn't respond except to repeat your question from above. You're so locked in your ways and want the rest of the world to follow your ways, that you no longer see the freshman error you make in your diagrams. When you label your nodes, the voltage between those nodes is derived from those labels. You therefore have zero volts from A to B. I have brought this up several times. Has it slipped your purview that no one has rushed to your defense on this matter?And why the circuits I have posted are, as you have claimed, wrong?
And I would really like to thank you for your contributions to this discussion. If it wasn't for your added brain power, this discussion might have carried on for 500 or even 600 postings.Keep going Ricky, you are really winning the argument now.:lol::lol:
The relative relationships would not make those results unexpected. Polarity vs direction. Learn it. I promise you will be better for it.Not sure what you mean by relative, but I wouldn't use that when paralleling the two windings of the secondary of a transformer, putting X1 with X4 and X2 with X3 might get some unwanted results.:blink:
That is a separate discussion. Sorry you can't see that. I have already said that the voltages in the same direction are in phase.If you agree with what this site had to say then you would also agree with this point they made almost at the bottom of that page I posted:
Now the laws are flexible? Where do you come up with this stuff?Why not? It's not like it would violate any of these flexible laws of physics.
You said they were not two sources. A single voltage source has two terminals. By definition, a voltage is taken between two points.
Not at all. the supply Jim D refers to has two hots and a common neutral.
Should have read:
The 120-0-120 is two hots and one common neutral with Van and Vbn both 120V and mutually displaced by 180degE.
Is that what your insurance company would say as they were completing the claim on your lab explosion? :lol:The relative relationships would not make those results unexpected.
Umm, you're the one suggesting the laws are flexible......I'm the one being very sarcastic about it.Now the laws are flexible? Where do you come up with this stuff?
But any time you want to compare to voltages, you MUST have a common reference. You should know that.Umm, here's a twist for you. Why do you think you need a common reference point in the first place? ... Voltages are determined between nodes regardless of a common point.
You're not.This is a real question. I am confused by this statement.
You can measure it and get the voltage of one terminal relative to the next, but you will have to have the measurement to a common point to compare the two original measurements.How can I measure a voltage without a reference point?
To compare any two of those, you will need a measurement to a common point. By summing in order, you build a reference chain. That is why the law works because if you make a loop, you will get back to to beginning and have closure at the original reference point.I didn't say without a reference point. I said without a common reference point. Standard KVL sums the voltages around a loop from node-to-node. When you perform KVL based on a common reference point, then you should be referencing all of your nodes back to that common reference point for their voltage. This gets very complicated and tedious. It still works and is still true, but the equations get needlessly complicated.
I told you if you did not understand post #98 and #290 you would not be able to follow along. I will simply refer you back to those instead of repeating it all over.A center tap 120/240 transformer has two 100 watt light bulbs wired to it. One on half and the other on the other half. How much current is on the neutral? Where does the current flow? Could this take place if they were 180 degrees out of phase with each other?
I'm sure I would get my story straight before they got there.Is that what your insurance company would say as they were completing the claim on your lab explosion? :lol:
My post was tongue-in-cheek.Umm, you're the one suggesting the laws are flexible......I'm the one being very sarcastic about it.![]()
NO!But any time you want to compare to voltages, you MUST have a common reference. You should know that.
I made that same observation many posts back. To me, it only hurts his credibility.How do your attempts to belittle those around you help you prove your point in this thread?
Isn't connecting something in phase order ABC and BAC is simply CHANGING one's chosen 'reference' point? Will it produce different results in a 3 phase motor rotation?
That's not a change in reference. That's a change in the physical circuit.
Good gracious Rick. Re-think what you just said as I think you got caught up in the moment.NO!
You do not need a COMMON reference. You need two reference points for each voltage. You know better than this!!! :dunce::dunce::dunce:
And your posting to me wasn't an attempt to belittle and I didn't simply throw it back in your face? Look at your contributions to this thread before you answer that.How do your attempts to belittle those around you help you prove your point in this thread?
You "can", but you are the one that said you "MUST" (your emphasis). Now you're backpedling and it is a "can" not a "must"?Good gracious Rick. Re-think what you just said as I think you got caught up in the moment.
You can measure the potential of node #1 relative to node #2. You can also measure the potential of node #536 relative to node #137. But you will never be able to discern the relationship between V_1_2 and V_536_137 until you establish a common reference. Come on now, that is basic electricity.
