- Massachusetts
Yer up a bit late, thanks for the positive reply.
I think you missed my sarcasm or maybe I am missing yours.
Personally I would like to see the size of the NEC decrease not increase.
How many pumps have you set like that?
Well pumps with remote capacitors?
Many.
I agree.Because a capacitor or control device may not last long in the environment that is 200 feet down, or it is at least much easier to change when it is not 200 feet down. They also mount them outside of hermetic refrigerant compressors and have no internal controls for similar reasons.
A lot. Dozens. Hundreds maybe.How many pumps have you set like that? Not even close to a good answer.
I think he does..... and Kwire has no clue.
I agree.
I think he does.
I've worked on a lot of pumps where the relay and/or the cap was in the pump. Most get replaced with a new pump.
I have also have daily visits from people coming into the shop wanting a capacitor for their well pump checked. I tell them "I'll give you good news if I have it, but most likely your problem is not a bad capacitor."
What is your point?
Ben: okay, why?
I don't have a clue where you are going with this, and don't appreciate all the suspense (mixed with the condescension). I like learning new things, no need to make it painful.
Wait a second - if your actual sentiment is "When is it better to place the cap remotely" (which is not what you said) then I have two observations. One, I generally don't have control over that. Two, I am indeed ignorant of an electrical reason to put the cap in the well.
I have replaced a cap in several wells, I'd tend to prefer an above ground one. I'd be curious as to why having it in the well would be better.
(Edit to add: I was writing this as you posted the previous.)
The answer is motor pump size. Two wire can only go up to 2.5 hp and used as a limiting factor for certain aquafir draw down requirements.
So what does designing or selecting a motor that doesn't need a capacitor have to do with needing a section in the code dedicated to submersible pumps. That is not what the NEC is about. Selecting the motor to be used is almost never the electricians decision in these installs.
I do not disagree that it may be possible to design a pump that doesn't need a capacitor. The larger the HP needed, the more challanging that becomes. We do have three wire motors with no capacitors - they are either connected to Monodrives or are three phase.
Design a new motor? Monodrives and three phase for residential? Let's stop the conversation at this point. Never seen a GFCI for a well motor circuit? Check out [680.51(A)] and [682.33(B)] Thanks for playing. Moderator....hit the button.
In my case, I had a 405' a 6" well drilled last week set 25' from the house. The casing is unscreened steel and is 64' set 10' into rock. The pump is 3/4 set at 240'. The electrical supply is 12/2. The water supply is PEX.
This thread seems to indicte that this casing needs to be bonded to the ground wire of the 12/2. Coreect? If so what is the best way to accomplish this?
I just drill the well casing and bolt on a lug...
Thats what I see on most installations.
(too often after it has been rejected for not being grounded)
