But inversion does create a phase DIFFERENCE, therefore the waveforms are NOT identical.   AC waves must have the same magnitude and phase to be identical.
Van carries a phase of (wt)
Vbn carries a phase of (wt + PI)
I didn't add anything to the phase constant, the phase constant of Vbn is PI, period.
Again, a deceptive answer and a lecture on transformers.
What did I say that is deceptive?
I have never hidden the fact that I am focusing my participation, in this thread, on the case of a single center-tapped winding which produces a standard 120/240V system.
I thought by maintaining this consistency, it would be clear that I have not changed topics in 'midstream'.
In this post your are asking about two different waveforms Van and Vbn. Their relationship is indeterminate without a common reference.
In previous posts you used Vbn and -Vnb.
By choosing the single center-tapped winding, per the OP, we have two voltages with the relationship of V1=V2. This is a statement of fact. It is an equality based on physics. There are several other ways to name, identify, or assign direction to these voltages, but V1=V2 is a fact while their physical relation remains unchanged.
If you want to discuss other two voltage systems and their waveform analysis, you may do so in a different thread.
It has been mentioned to you several times that you are effectively creating a double negative, do you see why this has point has been raised?
Using the subscript conventions we discussed previously:
Vxy can only become Vyx be swapping, or inverting, the reference from point Y to point X, effectively changing the direction of the voltage.
V@0? can only become V@180? by adding/subtracting PI, or 180? to the phase constant, effectively changing the direction of the voltage.
Using Vyx@180? effectively changes the direction of the changed direction, resulting in no direction change at all.
I am patiently waiting for you to post the results of performing a subtraction (240V-120V=??) with your phasors.
But I am also waiting for someone, maybe Besoeker, to post the waveforms of Mivey's circuit of Vbn@180? sharing a common point with Vnb@0?. Maybe this would help you answer your question, which you accuse me of avoiding.
