hillbilly1
 - North Georgia mountains
 - Owner/electrical contractor
Around here, there is a lot of mobile homes with 200 amp services using back to back 2" plumbing pressure 90's.
			Using white PVC plumbing pipe is unsafe! What happens when the landscaper cuts into a 1 inch ?white? PVC pipe that has 480 volt site lighting circuits, that he believes is the sprinkler water pipe.
Just my 2 cents.
None of which makes the installation inherently unsafe.
It could be or it could not be.
If he didn't know enough to use the right fittings did he know to ground properly?
For all we know he may have an old extension cord in that conduit and not even connect the ground wire ( I would bet on NM in the conduit as I see it all the time).
You normally only see the tip of the ice berg until you investigate farther.
The installer needs to be asked just how much coin does he save the church if it catches fire? If it does catch fire is he liable? God will likely forgive him - the general consensus of the congregation and especially the churches insurance company, may not be so forgiving.I ran into this very situation recently at a church. Sad thing is I'm sure it was a well meaning church member trying to save the church some coin. Cpvc pipe with 16 guage extension cord on a 20A breaker..... all over the place!
Arbitrary. They may very well have been qualified. Just chose to do it this way.
There is absolutely nothing unsafe or unservicable about this installation, forgetting for the moment whether it meets code or not. By itself, using plumbing pipe on its own it is not something I would be all that worried about. It is not the first time someone has used plumbing pipe of some type to run wires in, and it won't be the last.
If the OP wants to use it as leverage to get some extra work, that is fine with me. Just don't claim there is some inherent safety issue that does not actually exist.
It's glad to see we have guys like you that promote hack work. I will stick with doing high quality work and having serious pride in what I do. I got an old toilet in my garage you can have for a j-box if you want:roll:
I do not see anyone promoting anything, we all see installs that homeowners and handymen do all the time, while I have seen some very dangerous work this would not be one of them, and I agree it could be up there for years without any problems if the circuit is properly protected by OCPD's while I amnot promoting this type of work it is done all the time and well there are bigger fish that need catching this minnow is too small and needs to be thrown back.
As for the commit that plumbing PVC or CPVC will turn to dust if exposed to sun or in the ground, I dont think you thought much before you made that statment, as there is millions of feet of it at pool pumps, in the ground sprinkler systems, and even on docks, so while many of us don't like to see such work we need to look more closly to what seeing something like this tells us when we do come upon things like this, if I was called to do a job at a place and see this, it would not be this I would be worried about, but I would be on guard to watch out for other violations that would be dangerous such as lamp cord wiring, over sizing OCPDs for circuits, and many other more dangerous DYS type work.
Oh by the way, white PVC pipe would be much cooler in the sun then gray so even the conductors would run cooler:lol:
Just by saying the installation is safe or may be safe is promoting hack work... why even say that? This is why we have so much hack work out there because guys say "oh that's fine... it's safe... nothing wrong... i see it all the time"
Regardless if it may be safe or not it's WRONG PERIOD.
I get the point that maybe we shouldn't say anything that may be taken to mean this is an acceptable installation.Now I see why continuing ed hours are increased every few years,
I find some of this hard to believe. I see White PVC pipe exposed to sunlight all the time, some even under pressure and still intact. I also quite often see a lot of electrical "gray" PVC pipe that turns almost white within about a year after it was installed. Dig down a just a couple inches and it is still gray, the dirt seems to block the sun, you have transparent dirt where you live?when we have electricians that think all PVC pipe is the same, sprinkler tubing is sunlight protected as many of the pool fittings, some of the white pvc plumbing pipe will turn to dust, the sun rays destroy the pipe a foot underground, we dig plenty of the hack jobs up, and there is little of any that looks like pipe left, after the radiation does it's work.
Years ago was repairing a damaged sprinkler, there were 3 or 4, 3/4" PVC pipe grouped together & the damaged one was on the bottom so cut a couple of them out of the way, turned out that someone ran a 14/2 UF inside of one of them, nothing happened but to this day I get POed when seeing white PVC used UG for electrical, but on the other hand in the 1960's the sprinkler pipe used around here was gray......
These people don't realize that the liability is greater than what the job is worth.kwired said:Even if the install would have been done to meet codes and standards that is not a guarantee something unexpected will never happen that does cause injury, death, or property damage.
Anyone notice that whoever installed this didn't use purple primer on the joints ? :slaphead:
Like I said before not all gray pipe is electrical rated, I worked in a food processing plant where they ran lots of gray PVC pipe for caustic soda, acid, chlorine sanitizers as well as other chemicals. Had gray elbows and valves and other fittings to go with it. I don't know if there was anything special about this pipe or if they just used it for easy identification that it was carrying chemical products. This was mostly 3/4 and 1 inch sizes, I guess they did have some gray PVC in 2 inch through 3 or even 4 inch on some main water lines. Most water piping generally was stainless if smaller than 2-1/2 inch, but there was some gray pipe in large sizes for some reason.
FWIW, I use the clear primer on all my PVC joints. The only reason the plumbing stuff is purple is so the inspector knows you used it on the joint.:thumbsup:It would only be required on the plumbing PVC.![]()
The grey plumbing pipe you saw was probably schedule 80.
