petersonra
- Northern illinois
- engineer
Years ago was repairing a damaged sprinkler, there were 3 or 4, 3/4" PVC pipe grouped together & the damaged one was on the bottom so cut a couple of them out of the way, turned out that someone ran a 14/2 UF inside of one of them, nothing happened but to this day I get POed when seeing white PVC used UG for electrical, but on the other hand in the 1960's the sprinkler pipe used around here was gray......
what code is violated by running UF underground inside a piece of water pipe?
