 - NE Nebraska
 - EC
Lots of stuff used to use the neutral as an EGC. For instance, old radios, old amplifiers, pretty much anything with a metal chassis that existed before a separate grounding conductor was part of the system.
I realize that, but most of what you mentioned was also 120 volt equipment, was there much out there that operated at 120/240 besides ranges and dryers was kind of what I was after? Every instance I have seen that 20 amp 125/250 receptacle it was used for an application that did not require a neutral and the neutral terminal of the receptacle was effectively only performing the function of equipment grounding, even if it truly was connected as a neutral.
