I have a situation where I have to power a boat lift motor. The motor is rated for 240v, but the avaliable power is 208v. I was planning on using a buck/boost transformer to get up to 240v. The lift owner wants a remote controller on the boat lift, this requires a neutral for 120v to power the electronics. I was thinking of running two 208v hot wires and a neutral to the buck/boost and then bringing two 240v hot wires and the same neutral (no connection to the transformer) to the controller. Will this work? Will I get 120v to neutral and 120V to ground?
