 - Placerville, CA, USA
 - Retired PV System Designer
When bicycling I tend to roll stop signs just a bit. Unless a kid is watching.
Tapatalk!
			Tapatalk!
Tapatalk!
I say the same about a speed limit. Go over 1 mph and you're breaking the law and putting others' lives at risk.
I am going to have to disagree with that.
Coming from an area where the posted speeds range from 55 to 65 on the highways but the average speed is 70-75 it is my opinion I put more lives at risk going the speed limit.
It is not speed that kills it is the difference in speed that kills. In other words going the speed limit and causing all others to have to slow down and change lanes to get around you only increases the chances of an accident.
IMO, **cowboyjwc** nailed it in Post # 11 !.....It IS all about integrity
and doing the right thing.
Either you will do things according to the [ applicable ] Code, or you
won't !
Of course, I love these kinds of debates.P.S. - nothing personal. Just friendly conversation :thumbsup:
Actually speed limits are set by the percentage of the speed that a certain percentage of the drivers are driving on a set piece of roadway. I'm not sure the actual formula, but say the speed limit is 35 mph and 90% of the drivers are clocked at 45 mph, I think the law requires that the speed limit be raised to say 40 mph. Otherwise it becomes considered a speed trap. Since I work for a jurisdiction (24 years today as a matter of fact) and drive one of their truck, I tend to follow the driving laws a lot more closely. You want to see someone not follow the traffic laws, follow a cop around for a while.:happyyes:It may not be your job to enforce the speed limit but it's your (and all of our) responsibility to obey the laws of this country. Have integrity. Do the right thing when nobody is watching. Most importantly, somebody, somewhere determined that a certain speed is the maximum speed on a particular road that one can travel and maintain reasonable safety. So everytime we speed even 1 mph over we are breaking the law and putting ourself and others in danger.
Sort of like the CMP gives us minimum standards to go by. You would say that something minor like staple placement is still wrong because 1) the book says its wrong. 2) it can lead to more violations. 3) people are expecting to buy the safest install possible so you're cheating them by cutting corners.
Also I agree with Kwired (that's actually twice in one week we've agreed on something) that going too slow can be just a dangerous as going too fast.
Here is a real life scenario- Running emt out of a panel. It needs to be strapped 36". At 37" I can hit a solid stud, at 36" I need to use a drywall anchor. I opted for the solid stud at 37".......Nit picky? You bet. Why nit pick? Because it's a simple one and yes we all miss something including inspectors so why not really make sure that you get the easy stuff done.
We've had this conversation before about why you have inspectors. So yeah, you put one to many conductors in a box, this time. Next time, two? How many becomes too many? Well guess what the code gives you that answer.
Panel clearance. Minimum 3'. Is 2' 11" close enough. Not in my book. Because pretty soon that becomes a matter of, well you gave it to me last time or you go to another city and start the "John let's us get away with that."....
Would you feel guilty and responsible if an accident occurred and someone was seriously injured or died even if you were going the speed limit and the other person was speeding? You were obeying the law, they were breaking the law.
It was iwire. I typed to quick.:ashamed1:Interesting info... I'll look into it.
Agree with ya about cops :happyyes:
Did you mean Kwired or iwire?
Would I slap the cuffs on you, real life scenario, probably not. Would I dangle them in front of you and ask you if you knew what the code said or if your boss did? Yeah maybe.:happyyes:Here is a real life scenario- Running emt out of a panel. It needs to be strapped 36". At 37" I can hit a solid stud, at 36" I need to use a drywall anchor. I opted for the solid stud at 37".
I think I made the right choice, and my boss did too. He is the one who said, "Go ahead.", when I told him what I wanted to do.
If you want to put the cuffs on me sheriff I won't argue, but I don't think you'll find a jury that will convict me.
You are correct and I knew the exception was there, but does he know the exception is there?:roll: Sometimes you just want to know that they know and aren't pulling the old, "well that's stupid, I've never heard of such a thing."Article 358.30 (A).....each EMT run between termination point shall be securely fastened within 900mm (3ft) of each outlet box, junction box, device box, cabinet, conduit body, or other tubing termination.
Sounds kind of cut and dried until you read the exception.
Exception No. 1 Fastening of of unbroken lengths shall be permitted to be increased to a distance of 1.5 m (5ft) where structural members do not readily permit fastening within 900mm (3ft).
Now we need to think of "securely fastened" ( a stud is more secure than drywall anchor) and "readily permit" ( kind of a judgement call ).
I take it that this exception would allow for the strap to be located at the 37" with a clear conscience for the inspector. By the way there are inspectors that don't agree.
How many here would never do something against code, even if you knew that 999,999,999 out of 1,000,000,000 times there would never be an issue and the house wouldn't burst into flames and nobody would die, because ,well, if the code says I have to do it this way I'm going to do it this way?
A staple 14" from box, No AFCI breakers, one or two conductors over box fill, etc.
Now, how many drive over the speed limit daily? Aren't speed limits and electrical codes basically the same thing? The powers that be give us guidelines to abide by to increase safety?
I think it's more dangerous going 70 mph down the highway in a hunk of metal than being a conductor over box fill. Especially with all the distractions in a vehicle... Radio, phone, food, etc.
:bye:
