I wasn't meaning to imply that anyone would deliberately do a shoddy install.  However, it seems you've probably never worked in a production carpentry shop or in the backstage areas of a theater, where the receptacles work loose from the covers, and covers from boxes, simply from use (and occasional abuse).  I've often seen and repaired loose receptacles and covers; there may or may not be a good path to ground across a loose receptacle or cover, so that's why I'm in favor of placing a ground jumper.  That extra 30sec of work is cheap insurance.
As for what's code, I believe that dimpled-corner covers are compliant without the use of a grounding jumper; you'd have to check their listing and installation instructions.  Code is a minimum, and in this case, one I'm happy to exceed.  Oh, and our local AHJ likes to see the grounding jumpers, so there's that.
SceneryDriver
