- Placerville, CA, USA
- Retired PV System Designer
Question is this a code rule or is it the elevator state inspector my reason is why would they use a shunt on a elevator .
One reason was already mentioned: If there are sprinklers inside the elevator shaft you may want to cut power to the cage and/or elevator motor before spraying water on it.
Not all shunt trips are for manual shutdown.
