- Windsor, CO NEC: 2017
- Hospital Master Electrician
The really sensitive issue is that smoke recall will bring the car down to the primary recall floor (usually) and open the doors. Then the fire fighters arrive, put their key in and use the car to stage men and equipment wherever their action plan calls for. Since their key overrides the elevator safety sequence, there is usually no way to do a second recall in the event the heat detector goes off. There is a potential for responders to be inside the car when the power dies. And if there's already enough heat to trip the sprinkler, here's hoping it keeps the fire at bay long enough to evac the responders. There needs to be more discussion on this issue between the fire alarm folks and the elevator folks, with the fire service thrown in for good measure.
It's not my job to train firemen that the little hat means you take your life in your own hands by using the elevator. They are more skilled in their job than I could pretend to be, I have faith in them.
