Looking around the site I can't tell if Siemens breakers are approved for GOULD panel boards ?
I have a 40 circ 3 phase 4w panel.
It's fed with 1/0's. (Guessing it's 225 a and it's fed 150a)
Over the years people have added tandem murray and Siemens and other manufacturers.
Some breakers (12) are used for store night lighting and are switched on and off at the breaker
Some of these breaker buss points are a bit burnt. I'm guessing because of the breaker rating but mainly because if the breakers being used as switches and the movement of the breaker and loosening the connection point.
I'd like to install a 100 amp 3 pole breaker in this panel and feed a new panel for these twelve lighting loads and a couple of other new loads.
Do you think there is any problem installing a 100 amp breaker on this panel board busses and would you think that the Siemens breaker in this panel would be ok ??
Thank you
Thank you
