mbrooke
Batteries Included
- United States
- Technician
No, just the editor portion
For me its posting stuff. Very fussy, and keep getting errors.
But how does the grass play into all that? It still lowers resistance.
Is there any part in IEEE that lets you have grass?
All I have seen have gravel - usually pea gravel or washed river rock ~1/2"
IEEE 80 Safety is AC Substation Grounding, is a good place to look.
You will want to read the rest of it.
Editor will not let me put this line at the top:
All I have seen have gravel - usually pea gravel or washed river rock ~1/2" ~ 6" deep
I don't recall anything.
However it has been 5+ years, since I was reading it.
We are required to put in a layer of gravel 6” deep. It is for step potential.
Yes, we have weeds occasionally, and spray them to keep them from the Substation. With all that grass it looks like it would also invite wildlife of some type.
1. Proper grounding calculations and grid design should result in acceptable touch and step potential voltages without the additional grounding platform grounding. However, since the operation of the switch places the operator directly at risk when a substation fault occurs, additional precautions are needed. This includes adding switch grounding platforms and a 3- to 6-inch layer of clean crushed rock that covers the entire area inside the substation fence and extends 3 to 4 feet outside the substation fence to reduce the risk of electric shock.
Animals, spellcheck changed it to AMI
Well, for one is mowing the grass, the accumulation of grass over the years creating compost dirt, and the inability to get vehicles around the Substation yard during inclement weather.
Another would be AMI also crawling through the grass and up on the structure causing even more trouble when they short out something.
Yes, and I hit “post reply” and nothing happens. I forget after awhile and hit it again I guess...
im on an iPad, maybe that’s the problem...
FWIW, another non-technical factor.
'Progressive' political entities like Seattle with municipal power company do not do everything by technical rationale.
For instance, since the early 1970s 1% of substation cost Is required to be spent on artistic effort and making substations 'look good', '1% for the arts"
https://www.historylink.org/File/10645
Also, what country is that substation in? Albania, Turkey ?? Note the spelling on the placard "Sistem 3" et. Al.
