olly
- Berthoud, Colorado
- Master Electrician
Is it common practice to use stab lock connectors in residential dwellings and small commercial instead of twisting wire using wire nuts?
it is becoming more common. there is always resistance to change, even with a product that has many advantages.Is it common practice to use stab lock connectors in residential dwellings and small commercial instead of twisting wire using wire nuts?
I'm sure its common but I find a design issue with wago's or stab in connections, the connection point of a stab in is based on a thin edge contact as opposed to a more solid surface connection found under a device bolt or twisted along other ( solid ) wires of a wire nut. I have to admit I have used them recently on recessed lights but that's because not much heat is subjected to the connection of a 17w LED trim load therefor I'll use them there but would never use stab ins on a heavier load like 2 or more amps.Is it common practice to use stab lock connectors in residential dwellings and small commercial instead of twisting wire using wire nuts
Spring clip connections have been out for some +20 years. The concept and installed history are neither new nor unproven. But, they are definitely becoming more prevalent, whereas the 'back-stab' is still only found in inexpensive wiring devices and has had limitations added to its use.I remember hearing stories that some people resisted wire nuts when they 1st came out.
One thing I know about stab ins period is the design is less than solid, I cant tell you how many times I've had to change out a stab in receptacle because of mirco arcing from downstream connected loads, eventually connection points become oxidized so much that the continuity eventually fails or the wiring insulation begins to melt down due to the overheating from the more aggressive prolonged arching. I never use the stab in under potential heavy loads but hey, that's me.have very little in common with the stab-in connectors found in inexpensive wiring devices other than the wire being inserted into a hole
In many respects knob and tube - soldered connections were a great design ... until rodents decided they liked the cloth outer covering for their nestThey were concerned the connection was inferior to the solder
The design of the push in wire connectors is much different that that of the stab in wiring devices. There is a much higher spring pressure and a much larger contact area in the push in wire connectors.One thing I know about stab ins period is the design is less than solid, I cant tell you how many times I've had to change out a stab in receptacle because of mirco arcing from downstream connected loads, eventually connection points become oxidized so much that the continuity eventually fails or the wiring insulation begins to melt down due to the overheating from the more aggressive prolonged arching. I never use the stab in under potential heavy loads but hey, that's me.
My experience was note # 8 ...mirco arcing from downstream connected loadsmuch higher spring pressure
If the K&T was installed properly, the lack of insulation on the wires shouldn't matter!In many respects knob and tube - soldered connections were a great design ... until rodents decided they liked the cloth outer covering for their nest
>waving hands< A minor detail!...'cepting it was allowed to be installed in the open.
>waving hands< A minor detail!Only touch 1 wire and there's no problem!
Most of the 'in the open' would be in attics and in the joists in the basement. Maybe in the garage; wire might drop down to a switch or two. IIRC, my uncle's shop was wired K&T, with a twist-switch on the wall for the lights.
If it's the hot-- as long as you're not grounded...If it's the noodle, yeah, no problem. If it's the 'hot', it's not problem......... after you're killed.
I do that too, but you have to on the new LED fixtures with remote drivers, there is not enough room for wire nuts. I was installing some architectural fixtures a while back, and there was barely enough room for the connector!I'm sure its common but I find a design issue with wago's or stab in connections, the connection point of a stab in is based on a thin edge contact as opposed to a more solid surface connection found under a device bolt or twisted along other ( solid ) wires of a wire nut. I have to admit I have used them recently on recessed lights but that's because not much heat is subjected to the connection of a 17w LED trim load therefor I'll use them there but would never use stab ins on a heavier load like 2 or more amps.
Wiring devices (e.g. receptacles) use a connection that is entirely different than a spring clip design.My experience was note # 8 ...mirco arcing from downstream connected loads
...not or more...?Personal preference: I love the 'lever nuts' for compact wire connectors. As small as push in and IMHO not reliable than wire nuts for stranded wire.
Jon
