Jerramundi
- Chicago
- Licensed Residential Electrician
Well that's the thing... the argument I'm currently making, while IMHO a valid attempt to clarify 240.4(F), just takes us back to the very beginning of this thread and the initial question posed by my OP... does this transformer, when wired for a two-wire single voltage output, qualify... despite the clear existence of more than two secondary coil wire leads.Sure, but "transformer secondary" is not a defined term in the NEC. They just switched up the language a little to combat the mind-numbing redundancy. In both cases what matters is the circuit configuration.
Cheers, Wayne
But now that I've bounced ideas off you all and received your much appreciated input, I think post #80 clarifies what the NEC is trying to prevent here.
That you may be correct about the transformer as field wired, not as manufactured.
