flashlight
- NY, NY
- Electrician, semi-retired
Coppersmith, I use heat tape in various places, particularly where pipes are on an exterior wall. It's not a safety hazard to run per se, but it does caution that it shouldn't be left on if the pipes are drained, not sure if they are just being super careful ?Let me say this again. Heat tape. Heat tape is designed for exactly the purpose of keeping pipes unfrozen. It's not a safety hazard to run. It will not burn out in a few thousand hours. It does not require an enclosure around the dishwasher. It requires no mods to the dishwasher. I have used heat tape to keep my RV water and sewage lines unfrozen in the middle of winter in NC. It works well.
I don't think it would solve the problem of water remaining in the pump, and not sure I would be able to blow all that out. I am leaning towards
running a cycle with RV antifreeze and not relying on anything electrical.
