drcampbell
- The Motor City, Michigan USA
- Registered Professional Engineer
So what is paint? Pigment suspended in resin. Pigments are mostly metallic oxides, which are non- or semi-conductors. Resins are mostly non-conductors.
But it hardly matters. If you have a good low-impedance ground, either the paint will conduct and a fault to case will clear the OCPD, or the paint won't conduct and a fault won't energize the metal. Either way, it remains safe.
