winnie
- Springfield, MA, USA
- Electric motor research
It is the same tension between learning long multiplication vs using a calculator when you want to be an accountant.
Frankly I would not want an accountant who didn't understand the math well enough to be capable of doing it by hand. But I would want them to actually use a calculator!
Are you a real electrician if you don't know how to solder splices properly?
IMHO the key is to know how to make a splice properly with the splicing hardware you are using, and know how to recognize a bad splice. Pre-twisting does have the benefit of making the spice visibly prior to hiding it behind the wirenut. Frankly my favorite part of using the LeverNuts, I can see all the wires are in place.
-Jon
-Jon
