wwhitney
- Berkeley, CA
- Retired
If you're willing to do a one year experiment with two such setups.That ratio can be confirmed or denied with a 10w panel and a watthourmeter.
Cheers, Wayne
Wake me up at the summer solstice. . .in fact, wake me when it's over. . .If you're willing to do a one year experiment with two such setups.
Cheers, Wayne
This one sticks with me.As much as the systems cost, it’s not worth it.
I know where there is a $60,000 system on a $40,000 house. It’s stupid..
That ratio can be confirmed or denied with a 10w panel and a watthourmeter. And your insolation can be checked as we are near the winter solstice.
Let's say a system with a Present Value of 60 kilobucks
on a tarpaper shack and
an Investment Horizon of X years.
The elec. generated is like an annuity to the shack owner.
Power grid or wind turbine elec. costs Y dollars per kWh and no panel maintenance costs.
What would have to be true for this to make sense anywhere on this planet?
that’s 3,300 kWh per month.Around here at retail, that’s > 40,000 kwh. I have no idea if that’s practical or not.
The shack or lack thereof is irrelevant.
I believe where it’s mounted at (shack or POC house) is very relevant.
The last thing you want to do is have these yahoos mount a solar system on a piece of crap house. With the cost of solar there is around a 10 year break even IF all goes well and you follow the right numbers.
Need a new roof in 10 years? It would be nice if the roof will last AT LEAST 20 years. And hopefully nothing happens to need early removal of these panels for maint. and repair.
I have tested (anti- islanding) new installs that were roof mounted and were close to needing a new roof when I was there.
And all the caulk these guys use on a roof install is insane. It won’t last...
The extremes of the values tells you the range, and the published insolation values for your location tells you the average and what variation you can expect.Um, no, you cannot confirm or deny PVwatts modeling of year round PV production (which is based on latitude and historical local weather data) simply by taking a couple of one time measurement. You can, however, go to https://pvwatts.nrel.gov/ and run the numbers yourself and confirm that Wayne is not lying to you.
More than a 4,000 sq ft house.
add demand and solar won’t keep up
I don't think you'll have to dig this deep, though, to see through the puffery of salespeople. Not lies, but puffery, so say the courts
To the response from retired,Whether the solar 'keeps up' with the facility. usually has little to do with its value proposition. Overproducing often runs into limits on what you get paid pack. Underproducing doesn't.
I’m saying that a $60,000 unit to have to put out 3,333 kWh per month per his figures, will not happen.
I have on file here a $60,000 install that is only 15.2 kW.
It’s not going to keep up with the required energy demands to produce 3,333 kWh per month the way people live normally.
Your kinda missing the gist of the entire conversation from my point...(I still don't know why it matters, but...)
Actually it's within the realm of possibility, and is certainly the right order of magnitude. For example if a $60k system produced 1.9kwh per watt per year and it cost about $2.80/watt to install it could meet that goal. These are very good numbers for residential but they do happen in the real world. And at more average numbers of something like 1.5kwh/W/yr and $3.50/W the system is still providing two thirds of that.
Btw 3,333kwh to 'live normally' is very relative. Me and my family use about 160kwh a month.
ran out of time...(I still don't know why it matters, but...)
A couple points ( some already mentioned by JB):
1. I doubt there are more sleazy lying sales people in solar than any other industry.
2. Off south panels may be fine from a payback/production standpoint. You really can't generalize here
3. Newflash: People do PV for different reasons. Maybe it's not about money/payback? How many Americans have a big dumb $60,000 truck that they don't need, no one ever says anything about that. I just spent $12,000 on 500 sq feet of tile and have a $5,000 bathtub, but I'm still pooping in an outhouse (sometimes on a piece of cardboard if I don't want to trudge thru the snow at 6:00 AM - yes in the winter in the Northeast. Screw you mind your own business I'll spend my money on whatever I want thank you very much.
