Got a call to hook up a hot tub tomorrow but it's calling for a 60 amp GFCI breaker and I'm striking out on finding something that'll fit in this panel
The panel is about 10ft away from the corner of the hot tub so it doesn't need a disconnect but it's looking like I need to install a standard trip 60 amp two pole in the subpanel and run it over to a 60 amp spa disconnect
Does anyone have any other ideas or is what I described above the best solution?
The hot tub pulls a max amperage of 45 amps on it's highest jet setting with the water heater going
