- Bremerton, Washington
- Master Electrician
One of our forum moderators, Karl Riley, wrote the book on EMFs and invented a gaussmeter. In this video he explains that most high levels of EMFs are from electrician wiring mistakes
His book is available on Amazon, https://www.amazon.com/Tracing-EMFs-Building-Wiring-Grounding/dp/146990201X
A link between power line magnetic fields and childhood leukemia was revealed in a 1979 health study. More studies in the U.S. and Europe supported these findings, including links to other diseases. But when careful measurements were made in schools, offices and residences it was found that most high magnetic fields in buildings were caused by certain common wiring errors, as well as by electric currents on water pipes due to grounding practices. Karl Riley pioneered a successful method of tracing high magnetic fields to the site of the error. A simple correction clears the field. Though his clients in 17 states may see him as an electrical Sherlock Holmes, he follows a simple, logical measurement sequence which leads him inevitably to the spot where the error was made. Correction is simple and obvious. His entire diagnostic method is spelled out in this book, for the use of electricians or technically inclined home owners.
A metal water pipe with current creates EMF as the magenetic field does not cancel (IE the two conductors in Romex create a magnetic field that cancels.
In the video its interesting that you can get EMF even with the circuit conductors in EMT.
