electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
Like I said before, the code says that as an alternate option, you can use an AFCI at first receptacle of a circuit if within 50 ft length of 14-2 or 70ft on 12-2 For a family dwelling. The code does not provide much more text on this nor answer further questions or examples, Such as providing diagrams such as they do in counter and wall receptacle spacing.
I have read the code but am paraphrasing to the best I can recall since I cannot get my 2020 NEC book out at the moment
I think you will need to get a code book in front of you and read the actual text . Basically that section does not work because there is no circuit breaker and afci receptacle combination that is approved and listed for that use
