Finding the breaker alone
Irving LaRue
Warrenton, Virginia
Electrician Apprentice
I recently had an issue at a customer’s house where I couldn’t find the circuit I was working on. I was troubleshooting a switch and the client had a 30+ circuit panel, with 2 subpanels, none of which were properly labeled.
If I had someone with me, this wouldn’t be an issue, but I was alone. I’ve had homeowners help me in the past, but that’s never ideal and this particular owner was an older gentleman who couldn’t help much. I tried flipping a few breakers, jogging up to the 3rd floor, and testing the circuit. This was frustrating, tiring and not ideal because there were people working from home in the house.
I found some testers online that will locate a circuit, but they work by plugging something into an outlet and testing at the panel.
I ended up replacing the switch while it was hot, which turned out ok, but I never want to do that if I don’t have to.
Any suggestions or recommendations for locating a circuit when alone? Thanks for the advice!
In many cases the receptacles in a room may be connected to the light cir. I have used an extension cord and plugged a drill into it. If the cord can reach the panel that makes it easy. If not then I lock the switch and make sure it is clear of anything.
I second the loud radio. I also will note they are difficult to come by in the loud variety nowadays, but I came across one at a GoodWill after searching local stores of the type where purchasing a portable loud radio with a 120 volt pigtail and no automatic battery backup 20 yrs ago was a snap. It's not a snap any longer. Most without the battery backup have clock radio's only and the speakers on those aren't big enough to do a proper job.
Why do so many electricians not have a circuit tracer/finder?? I mean I would think if I was a homeowner and saw an electrician doing trial and error or a loud radio or some other half baked scheme I would think it was pretty mongrel...... That said, I've been doing this for 22 years and just bought a circuit tracer a few months ago 😂
Those circuit tracers have extras that you either buy or they come with it that let you connect to a light socket or just the wires. There is a pigtail to plug the "sender" part of the tracer in to. You can always buy a pigtail socket with alligator clips and buy a screw in receptacle socket and use the tester with that. This is actually what comes with some.
I learned very early in my career that you need some "help toys" if you're working alone!
Buy one that plugs in but make a short pigtail with nm and a duplex receptacle. One end is free so you can connect it to wires directly and you plug the device into that receptacle
I made mine with a two prong female cord cap, flexible cord, and alligator clips
The OP wanted to find the circuit, to turn it off, so that he could swap out a switch.
Almost all the suggestion involve 10 times the work, or 10 times the safety risk as it is to just change the device hot
