ggunn
- Austin, TX, USA
- Consulting Electrical Engineer - Photovoltaic Systems
How so?I remind the keyboard geniuses that 6 volts can kill. And wait for the response...
But why would you?Just apply 6 volts directly to the heart! It's current that kills. 10 mA will do it. 6/.01=600 ohms. So you have to get the 6 volts under the skin layer to get that low of a resistance.
Well, OK, but there's no way 6V can kill you under anything resembling normal conditions.Just apply 6 volts directly to the heart! It's current that kills. 10 mA will do it. 6/.01=600 ohms. So you have to get the 6 volts under the skin layer to get that low of a resistance.
I am not following this argument.
you won’t get shocked if the egc isn’t hooked up to the yoke and the hot touched the yoke, it would be like touching a hot wire as long you’re not grounded you won’t get shocked. Ex; touching the grounded metal box or aren’t standing barefoot on wet concrete, leaning on a steel i beam, etcYeah, I still don't follow. Neither of those things are true. Okay, in the first instance, if you're grounded to something else (not the yoke) and you energize the yoke with the hot, then if the yoke is already grounded you'll get an arc flash, and if the yoke is not yet grounded it will now shock you if you're holding it. In neither case can you count on a breaker tripping (although if there's a good GFCI then that's better).
I agree with how you hook up switches and outlets anything else like a light, etc I leave the ground hooked up. But you’d definitely get shocked if you had the egc hooked up and were holding the yoke with your bare hand and you touched the hot with your other hand, or you touched your strippers metal while stripping the hot or your screwdriver metal shaft while tightening the hot. Current will go through you and not trip the breaker as the ckt isn’t intended to protect you. If you touched the hot directly to the grounded yoke sure the breaker will trip but you may also as well IMO. I recently did this is how i know lol. As long as you’re not grounded it goes against safety to do anything hot but much safer in my eyes leaving the ground til last on switches and receptaclesHe's saying that connecting the EGC first makes the breaker trip, as an EGC is intended to do, instead of shocking you if you're holding the yoke.
@jaggedben yes if you were touching ground somewhere else sure you’d still get shocked.you won’t get shocked if the egc isn’t hooked up to the yoke and the hot touched the yoke, it would be like touching a hot wire as long you’re not grounded you won’t get shocked. Ex; touching the grounded metal box or aren’t standing barefoot on wet concrete, leaning on a steel i beam, etc
Golf carts are normal.Well, OK, but there's no way 6V can kill you under anything resembling normal conditions.
Has anyone ever been electrocuted by a 6V battery on a golf cart? It does not matter to the current in a circuit how much available current a voltage source like a battery has as long as it has enough to not droop under the load connected to it. A single 6V golf cart battery or 100 of them in parallel makes no difference; the current through a high resistance load like a human body is the same. Ohm's Law still holds; I = V/R.Golf carts are normal.
A friend of mine had a car with a nice wrench-sized notch burned through the fender next to his battery. Somewhere there's a matching wrench and some ruined underwear.I had to get a battery in a hurry once and stopped by Autozone. The boy that was installing my battery hooked up the ground first and had a ratchet handle a mile long. I stopped him and asked him to take the ground off and put the positive on first. I asked him if anyone ever explained about connecting batteries. He said they just showed him the tools and said to do it. After I explained the dangers of it to him he understood and was a little pale thinking about all the times he had escaped the danger!
You can tell someone to always connect the positive terminal first and disconnect it last, but until they do that they probably won't remember. Then they will.A friend of mine had a car with a nice wrench-sized notch burned through the fender next to his battery. Somewhere there's a matching wrench and some ruined underwear.
Why would you do that if no one has been killed by a battery? Certified.... hhmm.You can tell someone to always connect the positive terminal first and disconnect it last, but until they do that they probably won't remember. Then they will.
What?Has anyone ever been electrocuted by a 6V battery on a golf cart? It does not matter to the current in a circuit how much available current a voltage source like a battery has as long as it has enough to not droop under the load connected to it. A single 6V golf cart battery or 100 of them in parallel makes no difference; the current through a high resistance load like a human body is the same. Ohm's Law still holds; I = V/R.
Because: to the negative terminal, only the positive terminal is hot; to the positive terminal, everything is.Why would you do that if no one has been killed by a battery? Certified.... hhmm.
It wasn't the guy holding the wrench that was damaged it was the metal fender. Twelve volts are not lethal, neither are six.Why would you do that if no one has been killed by a battery? Certified.... hhmm.
