LarryFine
- Henrico County, VA
- Electrical Contractor
I know how to avoid a shock. That's why I use the pliers.@LarryFine
I guess holding the device with the pliers is a good idea, more so if the ground is hooked up and you’re landing the hot but can’t hurt. If the ground isn’t hooked up you could touch that yoke with the hot all day and not get shocked but who knows the other variables like what you’re standing on.
I want to avoid an arc. That's why I connect the hot first.
Yes. Presuming equal impedance in the hot and EGC pathways, you would be exposed to half of the L-N voltage (60v) for the duration of the fault current.Question for you, if you did land the ground first and we’re holding the grounded yoke with one hand and had the hot wire held by the insulation firmly and that hot hit the yoke, the ckt should trip but could you also get shocked by holding the yoke with one hand at that same moment?
