ggunn
- Austin, TX, USA
- Consulting Electrical Engineer - Photovoltaic Systems
Likewise, incandescent lights only waste power when they are on. What's your point?CFL's only "save" when they are on.
There is no result of dividing by zero, it's mathematically impossible (some software will return "not a number" as the result).0/0=0
It sounds good, but the fact that we have serious power issue in US says otherwise. If everything was just "ahhh, barely noticeable", then we would never have power issues. The facts are, all the littles things are seen and are issue for power sources. The issues are not "individual" issues, the power issue sums up back to the source. 40,000,000*0.2mA*120vrms parasictics = 8,000A*120v = 960kW lost at endpoints, then you need to add in transmission losses for that ~1MW, etc. Maybe end user electric meter cant see 0.2mA, but the source sure does.
Many electronic switches have a led on the switch or use little current to keep the electronics working with the wifi/bluetooth and what not. Maybe the current on the neutral is keeping the lights on. Try switching to a no neutral electronic switch if available.Hi there, so I have a GFCI receptacle controlled by an electronic Lutron switch. From this receptacle I plugged a string of LED lights together using extension cords. When I turn the switch off, a set of the LED lights stays lit. With the switch off, I measured 37V to ground at this receptacle. Any ideas what is going on here?
I was thinking maybe faulty receptacle or switch, maybe incorrectly wired. A colleague mentioned that if you plugged an incandescent light bulb into the circuit the problem would go away, but he could not explain why.
Thanks,
Switching from incandescent to CFL and LED did save energy in the perspective that you would still want similar light output and for similar times of use after the conversion. All them use no energy when not in use.You mean zero gas mileage, there are no miles when it's parked, no gas either. 0/0=0. If you push your car around with your own feet, the car gets miles with no gas use.
My point of "only when on" is that the "savings" is in that context. Parasitic is not. There is no savings when the item is off (not when the caomparison is two bulb types in the ON state).
Instead of spending $6 to save $5, why not just run TV ads that say "hey, turn off those lights you are not using", because when they are off, the more that are turned off, the less power drain on the grid.
When the power sources are lacking and the message is "hey, just turn that off", the power folks get lazy and see that the demand is now much lower, hence no need to maintain 20Gw generation when 10 is good enough, and then one day everyone turns all the lights and HVAC to ON. Voila, brown and blackouts.
Diversity in power use cannot and must not ever exceed max capacity. But, CA knows very well that their power is exactly that, not enough capacity. If people need 40Gw at any given time, then the power folks need to maintain at 40Gw(min).
I think at some point they need to stop saying "use less water, don't turn your lights on, turn your AC up 3 more, stop using water, only charge your eV after 6pm" and start figuring out how to supply more energy and supply more water, to meet the demand of it's users. If I pay for a 200A service and I use 240V180A 24/7 and 95% is wasted power, I paid for it and the service should accommodate me, otherwise why do I have a 200A service? I did not elect for my panel to be 200A, someone else decided that my home needed a 200A service.Switching from incandescent to CFL and LED did save energy in the perspective that you would still want similar light output and for similar times of use after the conversion. All them use no energy when not in use.
Did we drop more energy load from the grid over the past 20 or so years by changing to more energy efficient lighting than we added with these "parasitic" loads over the same time? Likely so. If anything we added load to the grid because of more things using electric energy along with there plain and simply being more users over time, but had we not gone with more energy efficient items as time went along the grid would be loaded even more than it is now.
Your answer fits no general math. 0/0 is an "indeterminate".There is no result of dividing by zero, it's mathematically impossible (some software will return "not a number" as the result).
Some utilities have billed in different tier rates as usage goes up. That is nothing new. Different rates during peak demand periods isn't new either. Might be a little newer for typical residential customers though.I think at some point they need to stop saying "use less water, don't turn your lights on, turn your AC up 3 more, stop using water, only charge your eV after 6pm" and start figuring out how to supply more energy and supply more water, to meet the demand of it's users. If I pay for a 200A service and I use 240V180A 24/7 and 95% is wasted power, I paid for it and the service should accommodate me, otherwise why do I have a 200A service? I did not elect for my panel to be 200A, someone else decided that my home needed a 200A service.
Maybe one day home electric will be billed like cell data plans, 1st 1000kWhr at some low cost, next 500kWhr at higher cost, and any extra beyond that 1500kWhr costs arm & leg & 1st born, per 30day bill cycle. That would force people to think twice about that service they pay for.
Maybe all moot if they can online nuke fusion in 10yrs. When that happens electric and H will be free. Wait, I take that back, electric and H will be arm & leg still.![]()
It fits exactly, and that's what I said- 0/0 is not a number. You can look it up if you don't believe me (I'll save some time- https://en.wikipedia.org/wiki/Division_by_zero. It deals with the reverse operation and if there is any number which when multiplied by zero yields that number; there is not.)Your answer fits no general math. 0/0 is an "indeterminate".![]()
Your math does not work. If an engine is running, it must be using fuel (energy) even if not much. If it is not running, there is no energy use and probably no distance traveled. And no "miles per gallon" since there no gallons used. In the end, you can say that the non-running car gets infinite miles per gallon, you could also say that it gets zero MPG; neither are mathematically correct.Look at it this way, if the running engine (in drive mode) get's 20mpg's (20miles/1gal) and you use no gal, you get no miles.
Proof: 20mi/gal * (0gal) = 0mi, thus 0mi per 0gal = 0mi/0gal = 0 (no miles and no gal).
Divide by zero is a specific class of answer, it's an "indeterminate", not "undefined" or anything other.It fits exactly, and that's what I said- 0/0 is not a number. You can look it up if you don't believe me (I'll save some time- https://en.wikipedia.org/wiki/Division_by_zero. It deals with the reverse operation and if there is any number which when multiplied by zero yields that number; there is not.)
This is how arithmetic works, I didn't make the rules.
For the physics nerds- this is like the concept that you can know exactly where something is or how fast it's moving (if moving at all), but not both. To measure velocity, you need motion and time, and when the object is moving, you cannot know where it is because by the time you observe the position, it has moved.... (poorly expressed but generally correct)
You surely do unless that motion is zero (where the positional change divided by time is 0 / time, or 0).You don't need motion and time-change to derive velocity.
Velocity is the directional speed of an object in motion as an indication of its rate of change in position as observed from a particular frame of reference and as measured by a particular standard of time (e.g. 60 km/h northbound).
I disagree. Leave it idle in park - engine is running it is consuming fuel but vehicle is going nowhere. Only useful work that maybe is being done is heating or cooling the passenger compartment or charging the battery or running any other accessories that might be used even if not traveling.Divide by zero is a specific class of answer, it's an "indeterminate", not "undefined" or anything other.
Non running engine is not infinite mpg's, we already defined the real thing, the engine, to be 20mpg when driving. It either gets 20mpg when running, or no mpg's when not running, there is no inbetween.
It's Heisenberg Uncertainty Principle, and it's not classical physics, it's quantum physics realm. All you need is two observers to know velocity (position, speed, and direction at any given time).
You don't need motion and time-change to derive velocity. Take any given velocity equation in vector format, you can derive instaneous direction and speed at any given time(t). You don't need any change in time to derive it.
Anyways, been fun, off topic. out.
0mi/10 gal, 0mi/11gal, 0mi/12gal, 0mi/15gal, gas tank now empty, engine dies, MPG's are still zero. That's the same as engine off, zero MPG's, except gas tank stays full.I disagree. Leave it idle in park - engine is running it is consuming fuel but vehicle is going nowhere. Only useful work that maybe is being done is heating or cooling the passenger compartment or charging the battery or running any other accessories that might be used even if not traveling.
But is an analogy of "parasitic load". Even less efficient in most cases but similar concept.0mi/10 gal, 0mi/11gal, 0mi/12gal, 0mi/15gal, gas tank now empty, engine dies, MPG's are still zero. That's the same as engine off, zero MPG's, except gas tank stays full.
