FionaZuppa
- AZ
- Part Time Electrician (semi retired, old) - EE retired.
I need to find a switch, preferably Eaton line, but other brands may work if their white color is close to the Eaton white.
Deco toggle dimmer for low watt resi LED light, but I need the dimmer actuator part to not be a slide control. Something like Lutron Maestro but the on/off needs to be more like the std deco snap toggle. Need to be able to "set" dim level and then use the switch w/o bumping actuator and changing the dim level. On Maestro you kinda have to hold the actuator up or down for a sec (or one push per level) to reach the dim setting desired and then it sticks there.
I looked through Eaton site and did not find one.
Suggestions?
Suggestions?
