As
@hillbilly1 is describing things, the rebar cage is not being used as an UFER, and a ground rod might help for coupling lightning spikes to ground.  But it seems like a huge wasted opportunity, because a connection to the rebar cage would likely provide a much better earth connection than a driven rod.
In fact, given the problems being considered (damage caused by lightning), having a good ground electrode (the rebar cage embedded in the concrete) very close to, but _not_ solidly bonded to the metal pole might be a recipe for disaster.
-Jon
