tyDoes it say aything about "flammable"? When last I looked -- admittedly some time ago -- contact cleaner contained alcohol and Freon™.
I'm quite sure the propellant is something different today, but I still wouldn't recommend it. Many modern refrigerants (propellants) are flammable, and a flash fire is only half your problem; incomplete combustion is also likely, which will leave carbon soot on the contacts.
Good grief! We would have been sacked for having a lighter in the industrial world we lived in!Got a lighter? Hold it up to the spray (safely pointing it away from everything) and see it it ignites. I’m going to bet that it does…
Also, being a float switch, it might be moisture intrusion. I would first do a quick spritz if WD-40, which is a water displacer (that’s what the WD stands for) and is electrically inert. But don’t spray that live either.
Safest bet is to never spray ANYTHING around a live electrical circuit.
This case arises from a tragic accident involving
appellant Faberge's hair spray product, Aqua Net. The appellee
Alison Nowak punctured an aerosol can of Aqua Net near a flame
and suffered severe injuries from the resulting fire. The jury
found that a defective valve system and inadequate warnings on
the hair spray can proximately caused Alison's injuries. She was
awarded damages of $1.5 million.
Lawyer around the corner from me won a 1.5 million judgement for a teenage girl that got badly burned by hairspray because it used propane for propellent.
You really have to be careful with aerosol can propellants
Non-conductive wasp spray exists specifically for use on live apparatus. Is it also non-flammable? I don't know.... Safest bet is to never spray ANYTHING around a live electrical circuit.
I looked up the SDS of two brands I have bought in the past and what's currently in my kit (Spectracide Pro, rated to 47kV). All flammable.Non-conductive wasp spray exists specifically for use on live apparatus. Is it also non-flammable? I don't know.
There may be a non-conductive and non-flammable contact cleaner out there, but why would anybody consider working on live equipment when it isn't absolutely necessary?
Don't look now, but the Internet just lived up to its potential.I looked up the SDS of two brands I have bought in the past and what's currently in my kit (Spectracide Pro, rated to 47kV). All flammable. ...
I really only use that kind of stuff to clean out gunk and dirt that is binding the mechanical operation. of contactsI was a maintenance electrician for 50 enjoyable years and spraying float switches and other controls are at best a short temporary fix. Best to replace it. I ripped a Ford so called mechanic when he told me that he fixed my brake switch by spraying contact cleaner on it. Less then a week later his so called fix failed.A few days later after complaing to Ford they told me they just came out with a recall and they would replace the brake switch. Only time that I used contact cleaner was on an old starter contact that we did not have either a replacement starter or set of contacts. Would use a contact file to clean contacts then spray but always replaced them ASAP.
Its flammable, a local hvac tech found out the hard way.Non-conductive wasp spray exists specifically for use on live apparatus. Is it also non-flammable? I don't know.
Never spray anything on energized circuits.
I just use 99% IPA as contact cleaner and the method pton described in post #5.
