Esay
- Rocky mount NC
- Industrial Electrician
I have a portable generator with an interlock device installed on my panel. I currently have a 30 amp breaker with four 10 gauge wires that go to a 20 amp reliance outlet. I would like to upgrade what I have to a 50 amp breaker so I can be able to power my heat pump with a larger generator. From what I gather, I will need at least a 10kw generator to be able to run a 2.5 ton HVAC. I read that 1 ton = 3,500 watts. 2.5 tons x 3,500 watts = 8,500 watts. I don't quite understand how to calculate the start up load for the heat pump. Attached is the tag for my unit.
