Treg the electrician
- lynnwood washington
- electrician
Inspector failed electrical on heat pump job stating that the disconnect needed to be fused. There was no issue with ampacity or wire size. On the name plate it gives an MCA and a max fuse size. It says nothing about MOCP it just lists those two categories. I have a correctly sized breaker. All NEC requirements are met. Does anyone have any advice on dealing with this? The installation instructions say that either a fused disconnect or a breaker can be used.
