I am specifying a Siemens 2000 amp 208V 3-phase main service switch. I will put a crown box on the top of it.
The service conductors are going to penetrate the top of the crown box and terminate to the switch.
The switchboard will freestand on concrete. This means feeder conductors cannot come out through bottom of the enclosure unless the floor is trenched.
Where is it appropriate for the feeder conductors to leave this enclosure?
Can it leave from the top through the same crown box or is that an issue?
Can the feeders come out through the sides of the switchboard or is that an issue?
Can the contractor cut the switchboard and connect a wireway on the bottom side of the switchboard to run feeders?
See my service switch below for reference
