herding_cats
- Kansas
- Mechanical Engineer
1600 kW comes from what other source?
Maybe locally where you are, but nationwide it's 40%.nearly 70% of all electricity currently uses natural gas as the fuel source.
Not really--it is more efficient and less polluting than burning diesel within the truck, and it makes it much easier to substitute even cleaner energy sources for the truck in the future.There's just something fundamentally wrong with using a natural gas generator to drive a turbine to charge an electric truck![]()
Yes, need a 2 meg wind turbine on site. No wind or not enough wind, you can't charge todayThere's just something fundamentally wrong with using a natural gas generator to drive a turbine to charge an electric truck![]()
I am not a fan of outside busduct...seen too many fail even thought they were rated for outside installation. I replaced a lot of outside busduct with cable bus for one client as a preemptive way of preventing busduct failureInstead of going underground you might consider using bus bar above ground.
Once they get the small modular nuclear reactors in service, I would see those as an answer for supplying power to this type of installation.Yes, need a 2 meg wind turbine on site. No wind or not enough wind, you can't charge today![]()
I doubt the EIA has been snookered, and they say (per the previous link) that in 2022 wind power generated 434 billion kWh, or 10.3% of US electricity generation.The usable power claimed from wind turbines is a total fraud. I have investigated this for years and this is what I have found. Wind power doesn’t make power, it makes money for a small group of people. Look at the current wind power situation: The landfills are piling them up.
When you generate DC and invert into the grid (like solar panels), it's quite easy.Please explain how wind turbines stay in phase also.
Oh boy, here we go....The usable power claimed from wind turbines is a total fraud. I have investigated this for years and this is what I have found. Wind power doesn’t make power, it makes money for a small group of people. Look at the current wind power situation: The landfills are piling them up.
If you want assistance with your OP, I suggest you desist from spurious claims like the above to avoid getting the thread derailed and closed.wind energy scam.
