ruxton.stanislaw Spammer
Suspended Member
- Arkansas
- Laboratory Engineer
Correction: this is true about the official standard being 208Y/120 V OR 120/240 V in a few Central and South American countries, and it will greatly depend on the area. In Mexico, you will see the same cans from 220Y/127 V banks being used, but wired differently for split phase. I suppose the medium distribution primary voltage may be lower in those rural areas or if applicable, they could be adjusting the transformer taps with the split phase service in mind so that the L-L voltage is not too high. I recall seeing a three phase single flux core transformer in Colombia labelled as "124/215v" - a totally non-standard voltage, but between the two.
