EMFExplorer
- Nashville
- EMF
I don't know anything about "ghosts"
Not my field lol.
Everything we do is AC magnetic fields. K&T as you mention is usually horrendous since the conductors are so far apart. All current will cause some fields since the conductors can't physically occupy the same physical space. But when the conductors are right next to each other in NM for example (well almost, sometimes the ground in the middle) they are pretty small.
When a load on a cable isn't balanced, then the fields cover a large area. Or if you want to look at it another way, the fields are much "stronger" - the readings are much higher. Fields from balanced cables/conduit drop off very rapidly. Fields from unbalanced cables/conduit do not drop off rapidly as you move the meter away from them.
This is the problem with the water pipe bonding...it creates an imbalance on the electrical service, the wire going to the pipe, and the pipe itself all the way back out to the street. There is an imbalance everywhere and a field everywhere. Break the pipe and all of that disappears instantly. No more transformer effect.
