Carultch
- Massachusetts
Usually, the way you'd make anything close to an idealized current source in practice, is with a voltage source that dynamically adjusts its output.I guess I wasn't clear in my question. I understand how voltage rise works in the external circuit if I think of the inverter as an idealized current source.
What I don't understand is how the inverter works as a current source, how it pushes out current. And whether the way it works somehow involves internally creating an even higher voltage that might be detectable at the inverter terminals as some epsilon of additional voltage, beyond what is attributable to voltage rise in the external circuit.
Thanks,
Wayne
I'm not aware of any kind of source that natively acts approximately as an ideal current source, without a control loop in some form or another to help it adapt to changes in the impedance of its output circuit.
