Anybody want to discuss that LCDI thing on window A/C cords?
And this fact is not lost on companies that have something to sell. I think it's the reason for the acceleration of the NEC as a product placement publication for manufacturers.
In most cases it is the manufacturer's representatives on the Standard Technical Panels that slow down the process. So even where the code requires a new device or product it may be a couple of code cycles before the product standard is changed and manufacturers have the new product on the market.
Sounds like the manufacturer has an idea for a product but won't even start R&D until they are assured they have a captive market when the Code requires it.
-Hal
-Hal
But even after there is a code rule, they often delay the changes to the product standard to comply with the new code rule. Just like with the code there is a lot of in fighting between various interest groups. Often there are manufacturers opposing other manufacturers.
This actually appeared for the first time in the 2002 code.
Very informative. Thanks for sharing post 16 & 17.
It appears substantiation must be offered with NEC code proposals, but is not fact checked before subjectively accepted or rejected by panel members, willing to participate in a 2/3 majority quorum, with their only common interest being the industry they represent.
I see all NEC panel members are industry representatives, including NRTL's, Engineering & Developer associations, the Insurance & Building-Materials industry, NECA, IBEW, Energy companies, Utilities, Device Mfg's, and several other groups.
Fact checking proposal substantiations appears less important than having common industry reps on same panel, with the same agenda?
Here are the comments on the LCDI code change.
Its unclear how the NEMA rep, or other panel members fact check substantiation details, peer review statistical analysis, or employ laboratory research with proposals, but my interest remains concerned with reporting the liability exposure to my clients.
Rather than debate how industry may shift liability risks to property owners, subject them to non-renewal & cancellation, if not complete loss after casualty, my place as knuckle-head tradesman is simply to observe & document my bid to abate the increased hazard.
A lot of proposals are rejected by the code making panels because the technical substantiation is not adequate. I think that is the most common reason for proposal to be rejected. In this case, most of the negative votes were from panel members who agreed with the substantiation and the concept and their only disagreement was that this rule really should be in the product standards and not in the NEC.
The NEC is an ANSI standard and that ANSI rules for the creation of standards specify that "stakeholders" be represented on the code making panels. The interest categories are the various stakeholders in for the NEC. The various interest groups are often at odds with each other in the code making process. Some panel members have "directed votes". That is the organization who they represent specifies the vote.
How many actual electricians are on the CMP's?
Totally agree with the negative votes - outside scope of NEC.
The problem is a product standards issue.
The NEC is already over-complicated for many users, especially the conscientious home owners and DIYers who want to be code-compliant. These are the folks who are forced to pay hundreds of dollars just to have ACCESS to the code requirements and then only to find it overloaded and overcomplicated.
In the interest of encouraging compliance I think the NEC should immediately:
* Be SIMPLIFIED for intelligibility by the every day user
* Be available at NO COST to the public
Since the NEC is a Legal Requirement, everybody should have easy access to its contents.
Common sense.
Anybody disagree?
Respectfully;
J R Saunders
Retired Safety Instrumented Systems Engineering Specialist
It is available for free at the NFPA website and it is voluntary as far as being adopted.
Have you submitted any PIs to make that happen? In general the code is not written by the Code Making Panel members or the NFPA, but by the interested parties that submit Public Inputs for changes in the code.
Homeowners and DIYers are not the target audience for the NEC, any more than they are for the International Residential Code (IRC) which specifies how framing and foundation, floor, wall, and ceiling construction is to be done. They're both written for professionals with training and experience, and by necessity cannot be excessively simplified for untrained readers. There are plenty of DIY self-help books on the market with the goal of doing that.
The NEC can be accessed for free on the NFPA website by just getting a free NFPA account. It's as loaded and a complicated as it needs to be, just like the IRC spends 30 pages talking about floor joists. This is a little like saying that Einstein shouldn't have used tensor field calculus when coming up with General Relativity in order to make it intelligible by the every day reader. Can't be done.
The NEC by itself is merely a voluntary technical specification written by a private ANSI-accredited developer. Legal requirements are defined by State and Local governments, and most of them reference some edition of the NEC in whole or in part. There's nothing stopping any of them from adopting a less-loaded and less-complicated code for their jurisdiction by modifying how they reference the NEC and which parts they reference, should they come to believe it's in their best interests to do so.
And again, everyone does have easy access to the NEC's contents.
seeing that with GFCI required on 30-50A exterior outlets, that are a cause of nuisance tripping of the certain AC units and subsequent TIA given to allow for UL to get a standard for the mfg. of these that "Will" work with GFCI. Until a Standard is made mfg. is not doing anything with making a product that will work. Seeing same on pool pumps now in NY since they required all these motors to be VSD.
Yes, until there is a product standard that specifies exactly what the NEC GFCI has to do, it is unlikely that a manufacturer will spend development money to make a change. If they spend time and money on something that they think will work, but it does not pass the performance requirements of the new standard, that is wasted time and money on their part.
Changing a standard takes at least and in many case longer than the 3 year cycle that the NEC is on.
With the pool pumps, Pentair was suggesting Siemens breakers, but they now have their own breaker....I suspect that it is just a rebranded Siemens breaker.
There are some design differences between the various GFCI manufacturers as the standard only specifies what the GFCI has to do, and not how to design it to meet the performance requirements.
A interesting 2023 decision by the DC court of appeals ended a decades long saga anyone is actually completely free to copy and distribute a PDF copy of the NEC (as soon as its adopted as law by reference), just like https://public.resource.org/ does. (They post them on archive.org).
According to the court its on the grounds of fair use, from pg 39 of the court decision:
The Court’s fair-use analysis faithfully recites the
governing four-factor balancing test, yet, in conducting the
balancing, it puts a heavy thumb on the scale in favor of an
unrestrained ability to say what the law is. Thus, when an
incorporated standard sets forth binding legal obligations, and
when the defendant does no more and no less than disseminate
an exact copy of it
, three of the four relevant factors—purpose
and character of the use, nature of the copyrighted work, and amount and substantiality of the copying—are said to weigh
“heavily” or “strongly” in favor of fair use.
Besides that the court also suggested your protected on at least four other possible grounds but did not need to explore them when the fair use settled the matter including the First Amendment and the Due Process Clause of the Fifth Amendment.
Cheers
Cheers
So if you're in the jurisdiction of the D.C. Circuit (District of Columbia) you can use this as a defense. Outside of D.C., you're still subject to getting Cease and Desist letters of the NFPA, I guess. I wonder why Public Resource hasn't relocated from Sonoma County (9th Circuit) to D.C. Probably because California Wine Country is a nicer place to live.
Personally, I don't find PDFs of scanned pages very useful. But my main point of contention wasn't so much ease of access, but with the notion that the NEC needs to be dumbed down so that it would be intelligible by someone who doesn't know anything about electricity.
