Jimmy7
- Boston, MA
- Electrician
I wired an inground pool for a friend of mine a little while back. The pool has steel walls and a liner with brick pavers as its decking. Rather than just bonding four corners of the pool, I installed copper direct burial lay-in lugs at each metal wall section of the pool walls. The pool walls are steel, I'm guessing galvanized steel. I also installed the copper grid under the pavers. I have been learning about solar lately and there is a lot of talk about dissimilar metals, so that got me thinking about the pool walls. As a result I contacted Hubbell, and they stated I could use the CL-50 DB Copper lugs on the pool walls if "I use Penetrox A on the mating surfaces, or use their CL501TN lug that is Tin plated". The pool is done, so I hadn't used the Penetrox A, or the Tin Plated Lugs.
As a result, my questions are this. Is this something I need to worry about? Should I see if I can install additional tin plated lugs where I can?
Thanks..
Thanks..
